AutoCAD P&ID General
Active Member
johnjpowelljr
Message 1 of 5 (224 Views)
Sline - Dot at Arrowhead
224 Views, 4 Replies
01-24-2012 09:47 AM
I have searched for hours for on this with no luck.
My slines have a dot at the very tip of the arrow. How can I get rid of this?
Thanks, a new P&ID user
John J
Product Support
jason.drew
Message 2 of 5 (200 Views)
Re: Sline - Dot at Arrowhead
01-25-2012 07:02 PM in reply to: johnjpowelljr
Is the SLINE connected to any equipment or fittings?
The plus sign indicates a disconnection and you can click it to continue routing the line:
The dot indicates the line is connected:
Jason Drew
Premium Support Specialist
Product Support
Autodesk, Inc.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly.
Active Member
johnjpowelljr
Message 3 of 5 (187 Views)
01-26-2012 03:18 PM in reply to: jason.drew
My problem is the engineers point out with thicker lines it looks like the weld symbol.
John J
John J
Product Support
jason.drew
Message 4 of 5 (171 Views)
01-31-2012 02:38 PM in reply to: johnjpowelljr
Hi John,
I'm a little confused on this one. If you run a process line and connect it to equipment, it does show a dot at end of the line, but only when it's selected and highlighted:
When it is de-selected it looks like this:
If you're wanting to turn off the display of lineweights in the view, you can toggle LWT button down in the tray:
Jason Drew
Product Support
Autodesk, Inc.
Sfarris2
Message 5 of 5 (167 Views)
02-01-2012 07:25 AM in reply to: johnjpowelljr
I had some Flow Arrows that were doing that on a drawing just the other day. I selected them all and made sure that the layer, color and lineweight were set correctly. Turns out that some of them had been changed to the wrong lineweight. Once I corrected that they plotted and displayed just fine.
You are not logged in.
Announcements
Need installation help?
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
