AutoCAD P&ID General
New Member
kslee
Message 1 of 3 (374 Views)
Save, Import, & export of Project Setup
374 Views, 2 Replies
09-12-2012 07:30 PM
Hai,
I have created a project, and made custom setup on the Project Setup-P&ID DWG settings-P&ID class definition.  I then modify the PIP workspace & pallete due to the standard symbols in the PIP not tally with our client's specification.
Question:
1. How do i save the whole setup and export ot copy to the second project from the same client.  What i did now was re-create the whole file again in the new project.
Thanks.
Product Support
quentin.contreras
Message 2 of 3 (338 Views)
Re: Save, Import, & export of Project Setup
09-14-2012 03:05 PM in reply to: kslee
You will go and start a new project from the Project Manager. It will bring up the Project Setup Wizard window, if you look at the bottom of the window you will see Copy settings from the existing project. The click the box and them find where you placed the project you made. You will be looking for the file called Project.xml. Once you select that, it will use the settings you set up from that project for your new project. I am also including a screen shot showing where to do this on the Project Setup Wizard window.
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Quentin Contreras
Product Support
quentin.contreras
Message 3 of 3 (318 Views)
09-18-2012 05:04 PM in reply to: kslee
Just checking back to see if the information I provided for you helped.
Quentin Contreras
You are not logged in.
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
