AutoCAD P&ID General
Active Member
Message 1 of 4 (738 Views)
Rename Class Name in project manager
738 Views, 3 Replies
11-20-2012 06:13 AM
I am required to use a french version of autocad P&ID 2013 and need to rename the class name descriptions in the project manager.
I am able to do this manually for each item , but it is taking a long time.
Is there a file that I can edit to change these items instead of having to go to each class.
thanks
Active Contributor
rchiasson
Message 2 of 4 (619 Views)
Re: Rename Class Name in project manager
12-05-2012 09:24 AM in reply to: graham1414
That I know of at the moment, there is no easy way for doing this besides individually. Similar if you want your equipment to come in a different color.
Keough
Message 3 of 4 (609 Views)
12-05-2012 01:06 PM in reply to: rchiasson
Unfortunately I cannot help with the renaming.
To change the color of all the equipment at once, you can try going to the projSymbolStyle drawing and changing the equipment layer color via the layer menu, this will affect anything on that particular layer in your project.
Valued Contributor
Message 4 of 4 (432 Views)
02-20-2013 06:03 AM in reply to: Keough
I have the same problem, is there a solution in 2013 version ?.  Which is the easiest way to change the class name and the Graphic Style in a line thats already drawn ?
You are not logged in.
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
