AutoCAD P&ID General
Valued Contributor
Grampster
Message 1 of 1 (121 Views)
Relief valves operator won't orient with valve discharge downward
121 Views, 0 Replies
05-20-2012 06:52 PM
Occasionally, you need to place a relief valve with the inlet horizontal and the discharge downward (i.e. to open drain). Draw a horizontal primary line, then turn downward. Now try to insert the relief valve. It will insert with the inlet coming from the downward line; the operator is oriented wrong. The work-around is to draw the primary line up, then horizontal, place the valve, rotate lines and valves, then move the results to where needed. Not exactly convenient. How can I correct the situation?
Sunetic Services
Owner/Consultant
You are not logged in.
Announcements
Need installation help?
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
