AutoCAD P&ID General
jbrumbau
Message 21 of 24 (400 Views)
Re: Reference to Project Database, DLM, PnPDatabase
07-06-2012 02:18 PM in reply to: jbrumbau
Ok, big problem with the PnPTables. I used txtFeedback on my .NET form for debugging purposes. All PnPTables come back with Rows.Count == 0. What am I doing wrong?
ProjectPartCollection projParts = PlantApplication.CurrentProject.ProjectParts;
Project oPrj = projParts["PnId"];
DataLinksManager dlm = oPrj.DataLinksManager;
PnPDatabase db = dlm.GetPnPDatabase();
PnPTables tbls = db.Tables;
foreach (PnPTable aTbl in tbls)
	txtFeedback.Text += Environment.NewLine + "Name = " + aTbl.Name + Environment.NewLine + "Rows = " + aTbl.Rows.Count;
 I then tried an alternative method:
StringCollection dlmNames = DataLinksManager.GetLinkManagerNames();
DataLinksManager dlm2 = DataLinksManager.GetManager(dlmNames[0]); //ProcessPower.dcf
PnPDatabase db2 = dlm2.GetPnPDatabase();
txtFeedback.Text += db2.Name;	//CRASH
PnPTables tbls = db2.Tables;	//CRASH
When I try to access PnPDatabase with this 2nd method, it crashes every time.
I'm running out of options here and I really need this to work. Please help.
Employee
lopezjo
Message 22 of 24 (397 Views)
07-06-2012 02:36 PM in reply to: jbrumbau
First method looks correct.
Jorge Lopez
Software Architect
Autodesk Plant Solutions
jbrumbau
Message 23 of 24 (387 Views)
07-09-2012 01:47 PM in reply to: lopezjo
Ok, so I finally got it to work. The 1st method I mentioned above does not work as all rows have .Count=0. After lots of searching I finally found something that works:
http://forums.autodesk.com/t5/NET/Accessing-database-tables-with-AutoCAD-PNID-2011/td-p/3166198
Apparently the rows and any other database items are empty due to a caching issue. To get around the issue, the rows should be obtained using aTbl.Select();
*/	//Does not work (due to caching issue?)
	PnPRow[] rows = aTbl.Select();
	txtFeedback.Text += Environment.NewLine + "Table = " + aTbl.Name + ", Row count = " + rows.Length.ToString();
}	//Works
Is there a line of code I can add to "cache" the tables properly? I know in Microsoft Access, if you do a RecordCount command on a query, on rare occasions it doesn't show everything and the sure fire method is to do a MoveLast command right before RecordCount. Is something similar going on here? These sorts of issues are programming nightmares, when functions don't behave as expected as it can take forever to figure out the problem.
Thanks for your help Jorge.
Employee
lopezjo
Message 24 of 24 (309 Views)
11-16-2012 10:16 AM in reply to: jbrumbau
Sorry I didn't catch the missing aTbl.Select() call when I initially responded. Our table objects only keep changed and new rows in memory for scalability reasons. Unmodified rows are fetched on demand from either a local cache or the project database depending on your environment.
The proper way to ensure you have a current list of rows is to always call Select() on a table.
Jorge Lopez
Software Architect
You are not logged in.
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
