AutoCAD P&ID General
aeiken
Message 11 of 14 (266 Views)
Re: Publish always fails
09-11-2012 07:11 AM in reply to: aeiken
Hi Dan,
I started looking at the system variables for AutCAD P&ID 2013 for publishing. I tried setting PUBLISHCOLLATE to 0 instead of the initial value of 1. That seems to have done the trick. I've been able to publish using the same old page setups that I've been trying since AutoCAD P&ID 2013 was installed. All sheets publish without errors. Publish seems to fail after the first drawing when PUBLISHCOLLATE is set to 1.
Ken
Product Support
Dan.Scales
Message 12 of 14 (265 Views)
09-11-2012 07:26 AM in reply to: aeiken
Hi Ken,
Good find.
I'll test this and log it with our developers.
Dan
Dan Scales
Product Support
Dan.Scales
Message 13 of 14 (259 Views)
09-11-2012 08:43 AM in reply to: Dan.Scales
Hi Ken,
I can't get the publish command to fail on my machine here.
I tested with PUBLISHCOLLATE and BACKGROUNDPLOT set to various configurations and I always get all drawings published.
Anyway, I am glad your issue with plotting was fixed with the PUBLISHCOLLATE variable.
Dan
Dan Scales
aeiken
Message 14 of 14 (252 Views)
09-12-2012 04:05 AM in reply to: aeiken
Hi Dan, BACKGROUNDPLOT was already set to 0. Ken Miller Instrumentation and Controls AEI | AFFILIATED ENGINEERS, INC. 5802 Research Park Boulevard | Madison, WI 53719 P: 608.441.6665 | F: 608.238.2614 kmiller@aeieng.com | www.aeieng.com
You are not logged in.
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
