AutoCAD P&ID General
Active Member
Message 1 of 6 (285 Views)
Problem with moving a control valve
285 Views, 5 Replies
06-18-2013 01:46 AM
Hello!
I have a problem if I move a control valve together with a line. The body of the cv and the line move to selected position, but the actuator of the cv moves the double of the distance. I attached two screenshots. I hope the problem is understandable and someone can help me.
Thanks in advance.
Before moving:
After moving:
craig.wood
Message 2 of 6 (265 Views)
Re: Problem with moving a control valve
06-19-2013 07:30 AM in reply to: TOPElo
We had a similar problem with moving objects in 2013. Some of the objects would move the desired distance, while others would move exactly double the distance. Autodesk confirmed the issue and supposedly have either fixed it in 2014 or are in the process of fixing it.
Craig
If my reply is a solution to your issue, please click the "Accept as Solution" button below...
New Member
Message 3 of 6 (108 Views)
03-12-2014 04:09 AM in reply to: TOPElo
This issue has not been dealt with in 2014 as we are having the same problem, how did you overcome this issue ?
craig.wood
Message 4 of 6 (90 Views)
03-13-2014 01:52 PM in reply to: TOPElo
C_Ryder,
The problem still persists for us as well, but primarily appears to manifest itself upon moving a larger selection of objects. Also, the objects that move double the distance are typically annotation-based items. To my knowledge, we've never experienced the issue with control valves.
Craig
Active Member
Message 5 of 6 (82 Views)
03-14-2014 12:05 AM in reply to: craig.wood
Hello Craig,
what do you mean with "Annotation-based items"?
craig.wood
Message 6 of 6 (56 Views)
03-19-2014 11:51 AM in reply to: TOPElo
TOPElo,
For us, the issue would happen only to items defined as annotations or items on the "Annotation" layer. I'm not sure which of these two was the determining factor, but either way text items would move double the distance.
Craig
You are not logged in.
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
