AutoCAD P&ID General
Valued Contributor
Message 1 of 4 (385 Views)
Pipeline Tag
385 Views, 3 Replies
04-04-2007 03:49 PM
I wanted to change the order of the Pipeline tag, so i did so. Now some of the attributes will not show up at all. I switched it back to its original order and it did not change anything. Did i mess everything up?
Valued Contributor
Message 2 of 4 (385 Views)
Re: Pipeline Tag, edit specs and fluid codes
01-05-2010 07:41 PM in reply to: hinde
I too wish to rearagne the order of the pipe line tag and I also wish to add in a another sub-part, only the sub-poart that i need to add doesn't yet exisit. I need to add an owner to the line number. I my case I have 4 areas of a plant all named, and each line number has an abbrevation for that plant so we know where abouts the line orginated from.
How and where do i add thsi information?
Also how does one edit things like the fluid codes and the specs to suite my project.
Active Contributor
Message 3 of 4 (385 Views)
Re: Pipeline Tag
01-06-2010 05:45 AM in reply to: hinde
Another forum user "flowers" gave me some good advice recently (Any good tutorials)... Review the getting started guide that comes with the install. With regard to this particular thread, refer to chapter 5 of the getting started guide (AutoCAD P&ID 2010) page 82 "Set Up Tag Formatting", it should help.
Regards
Tim
*Peter Quinn \(Autodesk\)
Message 4 of 4 (385 Views)
01-06-2010 09:10 AM in reply to: hinde
Mel,
Go to the project manager and right click on the project. Select properties.
In the project properties/setup you can edit the specs, services, etc.
Peter Quinn (Autodesk)
wrote in message news:6312925@discussion.autodesk.com...
project.
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
