AutoCAD P&ID General
Member
Message 1 of 4 (490 Views)
Accepted Solution
Pipeline Tag Style - Unable to retrieve tag format string
490 Views, 3 Replies
07-26-2012 07:16 PM
I am new to Plant 3D and the following error is shown when tagging a process line:
"Unable to retrieve tag format string for tag style: "Pipeline_Tag"
Can any one advise explain why this occurs and how to fix this please?
Thank you.:smileyhappy:
Active Contributor
Message 2 of 4 (488 Views)
Re: Pipeline Tag Style - Unable to retrieve tag format string
07-27-2012 12:17 AM in reply to: JofromOz
I assume you try to Tag a pipe line segment in a P&ID drawing. the message looks to me as the "string" the complete Tag is made of uses properties which do not exist anymore.
Enter the "Project Setup" go to P&ID DWG Settings-->P&ID Class Definitions-->Engineering Items-->Lines-->Pipe Line Segments. In the section "Tag format" you should see "Pipeline Tag". Select it and then click on Modify to open the Tag format setup dialog. Then start checking if all the properties used in the Tag format do exist and are valid.
I hope that helps.
Carsten
Member
Message 3 of 4 (472 Views)
07-30-2012 03:23 PM in reply to: cbeinecke
Appreciate your advice Carsten.
In the project set up details the default value was "blank" for the tag format on the primary line segment.
The "pipeline tag" was selected from the drop down list and applied.
The process line tag is now working correctly.
Thanks once again. :smileyhappy:
Active Contributor
Message 4 of 4 (466 Views)
07-30-2012 09:33 PM in reply to: JofromOz
Glad to be of helb. Appreciate the feedback.
Carsten
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
