AutoCAD P&ID General
nikoR
Message 1 of 7 (1,051 Views)
PLANTDEFINECALCPROPERTIES - How to include Pipe size information?
1051 Views, 6 Replies
02-19-2013 07:25 AM
As there seems to be no easy way to combine pipeline Size information with PLANTDEFINECALCPROPERTIES -tool, is there some trick to overcome this problem? ToString(Size) or ToNumber(Size) don't help.
What might be the reason for this? As the Size is typically of the most important data in line info; should be possible to get it...?
Thanks;
Niko
dave.wolfe
Message 2 of 7 (1,033 Views)
Re: PLANTDEFINECALCPROPERTIES - How to include Pipe size information?
02-19-2013 09:59 AM in reply to: nikoR
You can't.  It's on our list of properties to add in P&ID (we only added it in Plant right now) in our Extended Fields plugin.
http://www.pdoteam.com/store/pdo-extended-fields/
Dave Wolfe
Isaiah 57:15
ECAD, Inc.
Tips and Tricks on our blog: Process Design, from the Outside
A P3D Authorized Reseller
nikoR
Message 3 of 7 (992 Views)
02-22-2013 12:06 AM in reply to: dave.wolfe
OK Thanks Dave. Let me know when you're added it into the Extended Fields plugin.
Also hope to get this functionality to basic P&ID product soon to make use of the PLANTDEFINECALCPROPERTIES utility.
Distinguished Contributor
cadwomen
Message 4 of 7 (954 Views)
02-25-2013 04:42 AM in reply to: nikoR
Hy
check your PM .
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
jhamilton
Message 5 of 7 (325 Views)
01-19-2014 08:54 AM in reply to: cadwomen
Actually you can add things like two fields together such as 2 string fields together to create one field or convert a fields to numbers and do math functions.
Example:  If you want to add the values of two fields together it would be (field1llfield2)    (Use the button that looks like two vertical bars or "ll" in between the fields.  Clost both sides of the expression with quotations.
To do math it might be something like ToNumber(Field1) + ToNumber (Field2)
nikoR
Message 6 of 7 (294 Views)
01-21-2014 01:57 AM in reply to: jhamilton
Thanks, this helped!
Especially putting quotations was something I didn't figure before. Size gave an error but "Size" works OK.
By the way, is there any possibility to put conditional rules there? E.g. IF field1 is empty THEN choose field2, otherwise field1.
--niko
dave.wolfe
Message 7 of 7 (265 Views)
01-22-2014 10:09 AM in reply to: nikoR
Yes, you can format and add values together. No, you still cannot get the Size property. It is calculated on the fly by the program. For some reason, that makes it unavailable in the PLANTDEFINECALCPROPERTIES command (per developers).
Dave Wolfe
Isaiah 57:15
ECAD, Inc.
You are not logged in.
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
