AutoCAD P&ID General
Distinguished Contributor
gschimmi
Message 1 of 5 (590 Views)
Object enabler for PID2013
590 Views, 4 Replies
01-10-2013 12:51 AM
Hello
Is there an object enabler for PID2013 so that I can edit PIDs with AutoCad?
Or is there any other way to do this?
G
Plant3D 2014 German
WIN7
Rave.Tam
Message 2 of 5 (586 Views)
Re: Object enabler for PID2013
01-10-2013 01:36 AM in reply to: gschimmi
If you can edit P&ID with object enabler, who will buy the software? Object enabler is used to view custom data inside custom object. Unfortunately, there's no object enabler available. However, if all you want is to edit the drawing, export it to AutoCAD first.
If my post answers your question, please click the "Accept as Solution" button.
Check out my blog http://lazcad.com
gschimmi
Message 3 of 5 (581 Views)
01-10-2013 01:58 AM in reply to: Rave.Tam
Hi
an export via dwg or dxf to AutoCad does not help. You can't pick any symbol and so you can't move or copy symbols.
Plant3D 2014 German
WIN7
Rave.Tam
Message 4 of 5 (577 Views)
01-10-2013 02:31 AM in reply to: gschimmi
you must use the P&ID exporttoautocad command. There's a similar command for AutoCAD but that doesn't work. However, you can only export one at a time.
gschimmi
Message 5 of 5 (572 Views)
01-10-2013 02:52 AM in reply to: Rave.Tam
This is what I've searched for
Plant3D 2014 German
WIN7
You are not logged in.
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
