AutoCAD P&ID General
Active Member
graham1414
Message 1 of 2 (320 Views)
Modify Blocks, Lines not updating
320 Views, 1 Replies
03-13-2013 12:58 PM
Why after making changes to the leader line (layer/color)0r a block  in the project manager I have to double click on the leader for it to reflect the new change I made.
Is there a variable or regen-all command the will update all the drawings when as they are opened?
This is not the first time I have had to double click on an item so it would show the new changes.
If anyone could help that would be great.
Graham
Rave.Tam
Message 2 of 2 (260 Views)
Re: Modify Blocks, Lines not updating
03-18-2013 07:56 AM in reply to: graham1414
Synchstyles should update the blocks. Not sure about the lines though. If you set SYNCHSTYLESMODE to 63, it will synchstyles automatically everytime you open a drawing. Do it for every drawing and then set the mode back to 42. 63 is not productive because of the lag when opening a drawing.
If my post answers your question, please click the "Accept as Solution" button.
Check out my blog http://lazcad.com
You are not logged in.
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
