AutoCAD P&ID General
Valued Contributor
Heckmeck
Message 1 of 2 (461 Views)
Accepted Solution
Modifiy custom block
461 Views, 1 Replies
09-20-2012 12:02 AM
Hi Everyone,
I got a problem, which I am pretty sure, is easy to solve.
I created a block, that consists out of several P&ID objects, lines etc..., using the "block" command.
I use it as kind of an assembly.
Now I want to change this block. But when I open the block in the block editor and try to move some inner parts of the block, I just can't. It says: P&ID objects cant be modified in block editor.
But the whole block itself is not a P&ID object...
Can anyone help me with this?
*Expert Elite*
Rave.Tam
Message 2 of 2 (458 Views)
Re: Modifiy custom block
09-20-2012 02:11 AM in reply to: Heckmeck
Any P&ID object inside a block cannot be modified, copied and deleted.
We have a lot of problem with this limitation especially when it was converted into an equipment. The only way was to explode the block or do not use any P&ID object inside a block at all.
If my post answers your question, please click the "Accept as Solution" button.
Check out my blog http://lazcad.com
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
