AutoCAD P&ID General
Valued Contributor
Heckmeck
Message 1 of 2 (464 Views)
Modifiy custom block
464 Views, 1 Replies
09-20-2012 12:02 AM
Hi Everyone,
I got a problem, which I am pretty sure, is easy to solve.
I created a block, that consists out of several P&ID objects, lines etc..., using the "block" command.
I use it as kind of an assembly.
Now I want to change this block. But when I open the block in the block editor and try to move some inner parts of the block, I just can't. It says: P&ID objects cant be modified in block editor.
But the whole block itself is not a P&ID object...
Can anyone help me with this?
Rave.Tam
Message 2 of 2 (461 Views)
Re: Modifiy custom block
09-20-2012 02:11 AM in reply to: Heckmeck
Any P&ID object inside a block cannot be modified, copied and deleted.
We have a lot of problem with this limitation especially when it was converted into an equipment. The only way was to explode the block or do not use any P&ID object inside a block at all.
If my post answers your question, please click the "Accept as Solution" button.
Check out my blog http://lazcad.com
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
