AutoCAD P&ID General
attila_vallyon
Message 1 of 5 (352 Views)
Lost size property, P&ID 2013
352 Views, 4 Replies
11-23-2012 05:04 AM
Hi!
From time to time I loose the size property of an inline element. Such as a valve or just a flanged connection. I should see for example 1" from a size tag, but I see only a dot. If I move the valve symbol on a pipeline a little bit than the size properties reappear and I get the proper size again.
But I do not want to do this again for all valves in a PID.
Any ideas?
Attila Vallyon
attila_vallyon
Message 2 of 5 (259 Views)
Re: Lost size property, P&ID 2013
12-04-2012 02:03 AM in reply to: attila_vallyon
I am a bit disappointed!
I have not got a single reply.
This forum is not helpful anymore.
Attila Vallyon
Rave.Tam
Message 3 of 5 (256 Views)
12-04-2012 02:45 AM in reply to: attila_vallyon
Try the tools on my website. There is a way to batch update the acquisition value.
If my post answers your question, please click the "Accept as Solution" button.
Check out my blog http://lazcad.com
attila_vallyon
Message 4 of 5 (251 Views)
12-04-2012 04:50 AM in reply to: Rave.Tam
Thanks for the reply!
I hope this helps! But I am not sure how to use this tool. Can you give a small description?
Thanks in advance!
Attila Vallyon
Rave.Tam
Message 5 of 5 (248 Views)
12-04-2012 05:09 AM in reply to: attila_vallyon
This tool allows you to select drawings from a built in browser, and batch run some specific commands on these drawings at once. One example is updating the size on valve (if it is not updated) on all the drawings.
1. Download the zip file on the download page
2. Follow the installation instruction on the same page
3. Check out post on this tool here
The command that you need to run is Update Acquisition and Refresh Annotation. As usual, backup your files before attempting this.
You are not logged in.
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
