AutoCAD P&ID General
Valued Contributor
Heckmeck
Message 1 of 5 (640 Views)
Layers - Annotations
640 Views, 4 Replies
10-30-2012 01:49 AM
Hi Everyone,
I have a little problem.
I have two different styles of annotations for each symbol. In the project configuration, I set each annotation to a different layer, so I can switch between the two styles, by switching on/off the respective layers.
Unfortunately, when I place a new annotation, it is not inserted on its supposed layer, but on the layer of its P&ID symbol.
I tried to manually change the layers of the annotations, but after a while the layers just switch back to their original layer.
Do you have any tips for that? Maybe it's more of an Autocad problem....
Rave.Tam
Message 2 of 5 (633 Views)
Re: Layers - Annotations
10-30-2012 04:11 AM in reply to: Heckmeck
Do you have "Use Target Property" turned on for the annotations? If yes, it will use whatever layer that the symbol is using.
And changing layer does not work for annotations, it will always reset to default.
If my post answers your question, please click the "Accept as Solution" button.
Check out my blog http://lazcad.com
Valued Contributor
Heckmeck
Message 3 of 5 (616 Views)
10-30-2012 11:55 PM in reply to: Heckmeck
Thanks for your answer!
Hmm...does not sound good. I have many target object properties in the block of the annotation.
Just for a try, I changed them all to "non"-target objects,.... they still work but the chosen layer remains still the layer of the p&id block.
Do you have any other tricks for achieving a drawing with two different sets of annotations? (easy switchable)
Valued Contributor
Heckmeck
Message 4 of 5 (611 Views)
10-31-2012 12:32 AM in reply to: Rave.Tam
Ohhh, my bad. I thought, you mean the target propertys inside the annotation block.
Now it works like a charm!
Thanks a lot!
Rave.Tam
Message 5 of 5 (606 Views)
10-31-2012 03:37 AM in reply to: Heckmeck
Glad it works for you
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
