AutoCAD P&ID General
ronjanssen30
Message 1 of 6 (1,006 Views)
KKS pipelines
1006 Views, 5 Replies
02-08-2010 12:22 AM
I am configuring AutoCAD PID with KKS codes and I have reached a problem which I cannot handle. For the equipment and valves I have set up the right coding and the corresponding annotation. When I do the same for the pipelines, the Tags do not increase in numbers. As you can see on the attached picture, I have 5 identic Tags, which should according to the database type of the program, not be possible at all.
Also when I annotate the pipelines, the same way as the valves, the annotation becomes C4GJB10BR000 instead of ........BR001 ........BR002 etc.
I even have removed the existing line Tags, and also have made the Tag and Annotation on the lowest level of the structure but it won't help.
Please help
ronjanssen30
Message 2 of 6 (1,006 Views)
Re: KKS pipelines
02-09-2010 10:00 AM in reply to: ronjanssen30
I have solved the problem today with someone from our support team. For pipelines, you have to use the PipelineGroupNumber out of the NonEngineering list. With this incorporated, the KKS-system can be fully integrated with AutoCAD PID. I am now busy with building all selection lists and it is gonna work really fine.
Active Member
TimGrace3759
Message 3 of 6 (1,006 Views)
Re: KKS pipelines
02-10-2010 06:23 AM in reply to: ronjanssen30
Where can I download a guide for using the KKS numbering system?
ronjanssen30
Message 4 of 6 (1,006 Views)
Re: KKS pipelines
02-10-2010 07:28 AM in reply to: ronjanssen30
If you sent me an email, I will return a complete KKS-excel selection list.
ronjanssen30@hotmail.com
Active Contributor
tim.grace
Message 5 of 6 (1,006 Views)
Re: KKS pipelines
02-10-2010 07:55 AM in reply to: ronjanssen30
will do thank you
adelgado
Message 6 of 6 (552 Views)
Re: KKS pipelines
08-07-2012 06:49 AM in reply to: ronjanssen30
Hi Ronjanssen30,
I'm introducing in KKS codes and I'm starting to set-up Autocad P&ID 2011 for KKS.
Could you send me by email your excel list?
Is there any way to insert this list into the Autocad P&ID database of the project?
Wich is the most similar tool palette for KKS european P&ID drafting? ISO, DIN, PIP, JIS....?
Thank you very much.
______________________________
TERMISA ENERGIA S.A.
http:\\www.termisa.es
You are not logged in.
Announcements
Need installation help?
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
