AutoCAD P&ID General
Valued Contributor
alvaro.nimasco
Message 1 of 2 (511 Views)
Item Preview Error
511 Views, 1 Replies
10-23-2012 02:08 AM
When I select a valve, pump, instrument, etc, in a P&ID drawing, and then click the blue little arrow in the lower right for previewing a replacement, this happen to appear wrong. I see the preview window, all white, like if all the items are in the back, description appears correctly, please see attache img.
Has anyone experince this before ?
thanks
Product Support
Dan.Scales
Message 2 of 2 (468 Views)
Re: Item Preview Error
10-26-2012 07:47 AM in reply to: alvaro.nimasco
Please delete the SubstitutionPalettes.xml file from the root of the project. This file with then be recreated when the project is opened and it usually fixes issues with the display of the substitution palette.
Dan
Dan Scales
You are not logged in.
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
