AutoCAD P&ID General
Active Member
graham1414
Message 1 of 5 (422 Views)
Instrument Symbols Plotting text mask
422 Views, 4 Replies
06-11-2013 09:00 AM
When I plot my drawings, the text inside the instr. symbols shows a shaded box around the
text/tag
Does anyone have any suggestions to correct this issue.
Graham
craig.wood
Message 2 of 5 (406 Views)
Re: Instrument Symbols Plotting text mask
06-11-2013 02:33 PM in reply to: graham1414
Please provide a screenshot preview of your issue.
Craig
Active Member
graham1414
Message 3 of 5 (391 Views)
06-12-2013 06:30 AM in reply to: craig.wood
Hi Craig,
I have attached a PDF of the problem. I think I might have found a solution, and that is to change the layer of the
text mask to a "no plot" layer.
But not sure if that's best way.
Graham M. MacIver
Montreal, QC.
CIMA+
Member
caverette91966
Message 4 of 5 (356 Views)
06-17-2013 09:05 AM in reply to: graham1414
Grahm,
These are wipeout boxes, and all you need to do is type in command wipeoutframe and change the setting to either 0 (which turns off the box frames, or 1 (which leaves the frames on and they plot), or 2 (which leaves the box frames on bus does not plot). I personally like the 2 setting so I can tell that there are wipeout boxes on the drwing I am working on in case I need to move things around.
Also, if you are going to be saving these down to an earlier version (say Autocad 2010), you will need to use the 0 setting as earlier versions do not reconize the number 2 setting. Hope this helps.
Chris
Active Member
graham1414
Message 5 of 5 (354 Views)
06-17-2013 10:11 AM in reply to: caverette91966
Thank you for the reply, I will give it a try and let you know how things go.
You are not logged in.
Announcements
Need installation help?
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
