AutoCAD P&ID General
Distinguished Contributor
gschimmi
Message 1 of 10 (726 Views)
How to sort in the report creator
726 Views, 9 Replies
10-24-2012 10:29 PM
Hello
I like to sort a report according to a field: number asc
This is what I get
1
10
11
2
3
4
How can I change this? I can't find a function like val(number) or format the numbers to 01, 02...
Thanks for any help
G
Plant3D 2014 German
WIN7
Product Support
gersteb
Message 2 of 10 (698 Views)
Re: How to sort in the report creator
10-26-2012 07:29 AM in reply to: gschimmi
Hi Guido,
What for a field do you want to order here? When I look to your list it seems that this field is defined as a string field but not a number field. You can look for the definition of the field in the project configuration. Switch to the Plant 3D class definition of your class and look for the property which you want to use. There is a column called 'property type'. Look for the value of this column.
Best regards
Bernd
Bernd Gerstenberger
gschimmi
Message 3 of 10 (663 Views)
10-29-2012 05:10 AM in reply to: gersteb
Hello Bernd
I like to order the field 'Number' from the class valves in the PID properties.
It is formatted as 'char' and I can't change this. So I look for an function or something that changes the field into a value in the report creator....
Best regards
Plant3D 2014 German
WIN7
Product Support
gersteb
Message 4 of 10 (658 Views)
10-29-2012 07:58 AM in reply to: gschimmi
Hi Guido,
Do the following:
  • Make a backup of your processpower.dcf of your project (a copy is enough).
  • Open the processpower.dcf with SQLite Database Browser. If you still haven't installed it, you can download it from several sites and use it for free.
  • Switch to the tab 'Browse Data'.
  • Select in the combo box the table 'PnPProperties'
  • Search for a row with TableName = HandVentiles  and PropertyName = Number
  • Change for this row the values of those columns:
  • PropertyType: By default: System.String, now: System.Int64
  • Length: By default: 255, now: -1
  • Save the processpower.dcf
Now re-open your project in the report creator and you are able to sort the column 'Number' 'correctly'. I have attached a result of my test: Number is sorted now with 1, 2, 10 instead of 1, 10, 2.
Please, mark this case as solved if I could help you but don't hesitate to ask for further information here.
Regards
Bernd
Bernd Gerstenberger
Valued Contributor
Heckmeck
Message 5 of 10 (638 Views)
10-31-2012 01:31 AM in reply to: gersteb
Hi Bernd,
recently I had the problem of not being able to change the data type of my attributes.
Could you please post, how to change the value to other data types? (eg. boolean, string, etc..)
I am sure, this would be helpfull for a lot of users.
Product Support
gersteb
Message 6 of 10 (630 Views)
10-31-2012 06:32 AM in reply to: Heckmeck
Hi Guido,
I have created a video here: http://screencast.com/t/fLGPRtMu
Does this help?
Bernd Gerstenberger
gschimmi
Message 7 of 10 (615 Views)
11-01-2012 12:45 AM in reply to: gersteb
Hi Bernd
that works fine
Thank you
G
Plant3D 2014 German
WIN7
gschimmi
Message 8 of 10 (578 Views)
11-06-2012 02:33 AM in reply to: gersteb
Hi Bernd
today I've tried to generate the report again. But all I get is the error message in the attachm.
When I look with sqlite database browser into the processpower, so there is 'number' declared as int64, like I've changed it some days ago. But in the project properties there is 'number' declared as string.
Something is wrong?!
Best regards
Plant3D 2014 German
WIN7
gschimmi
Message 9 of 10 (571 Views)
11-06-2012 04:40 AM in reply to: gschimmi
Hi
the reports work now after clearing PLDC
the different declaration is kept
G
Plant3D 2014 German
WIN7
Product Support
gersteb
Message 10 of 10 (564 Views)
11-06-2012 07:40 AM in reply to: gschimmi
:smileyhappy:
Bernd Gerstenberger
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
