AutoCAD P&ID General
Distinguished Contributor
Tee.Dee
Message 1 of 4 (482 Views)
How do I change default value of Property '*Type'
482 Views, 3 Replies
02-14-2013 07:10 PM
For example under
Project Setup > P&ID Class Definitions > Engineering Items > Equipment > Mechanical Drivers > Motor
I want to change the 'Default Value' of the Property named *Type.  Is it possible to make the default anything other that what is in the pulldown list? Am I able to create a custom list somewhere?
Thanks.
cadwomen
Message 2 of 4 (471 Views)
Betreff: How do I change default value of Property '*Type'
02-15-2013 12:36 AM in reply to: Tee.Dee
myby you shoud read the help
cw
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Active Contributor
georgeendrulat
Message 3 of 4 (458 Views)
Re: How do I change default value of Property '*Type'
02-15-2013 05:31 AM in reply to: Tee.Dee
Project Setup > P&ID Class Definitions > Engineering Items > Equipment > Mechanical Drivers > Motor --> Click on "List" under "Property Type", while it is selected on the very right hand side click "Edit...".  From there you can modify the list.  Once you have modified the list to your liking, whatever you choose it to say under "Default Value" will be the default value.
Tee.Dee
Message 4 of 4 (331 Views)
03-03-2013 02:47 PM in reply to: Tee.Dee
Sweet, thanks for the help!
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
