AutoCAD P&ID General
New Member
mhaya
Message 1 of 11 (626 Views)
Ghost Lines on the Data Manager
626 Views, 10 Replies
02-14-2012 09:53 PM
I have encountered some lines that appear in the data manager; however, they do not exist in the actual drawings, and they wont zoom into the actual location in the model space. Is there a way to delete these unexisting lines from the data manager? I have tried purging the drawings, but to no avail. They still can't be erased.
nikoR
Message 2 of 11 (621 Views)
Re: Ghost Lines on the Data Manager
02-15-2012 01:18 AM in reply to: mhaya
Try running AUDITPROJECT -that should remove the ghost objects.
adelgado
Message 3 of 11 (580 Views)
03-07-2012 03:43 AM in reply to: mhaya
I have the same problem but Auditproject doesn't works. :smileysad:
______________________________
TERMISA ENERGIA S.A.
http:\\www.termisa.es
nikoR
Message 4 of 11 (577 Views)
03-07-2012 03:47 AM in reply to: adelgado
Version? With PID2010 doesn't remove all, with PID2012 it should.
adelgado
Message 5 of 11 (575 Views)
03-07-2012 03:49 AM in reply to: mhaya
It is 2011
nikoR
Message 6 of 11 (572 Views)
03-07-2012 03:53 AM in reply to: adelgado
We haven't experienced such with 2012 at least, so possibly an update to latest version might help. It has varioius other enhacements as well.
Valued Mentor
ybogdanov
Message 7 of 11 (547 Views)
03-15-2012 11:34 AM in reply to: nikoR
Open the database(ProcessPower.dcf file in the project) with SQLite Manager (FireFox plug-in) and delete the lines.
Yury Bogdanov
ASIDEK(Grupo CT) - Partner Directo de Autodesk
Barcelona (Spain)
panchozu
Message 8 of 11 (422 Views)
08-29-2012 03:13 PM in reply to: mhaya
Hi, i have the same problem, but in P&ID 2013 (P3D), could you solve the problem?
*Expert Elite*
Rave.Tam
Message 9 of 11 (416 Views)
08-30-2012 07:43 AM in reply to: panchozu
Purge the drawing (check the box that says purge zero length....)
then run "Audit"
If my post answers your question, please click the "Accept as Solution" button.
Check out my blog http://lazcad.com
panchozu
Message 10 of 11 (411 Views)
08-30-2012 08:10 AM in reply to: mhaya
purge drawing, with the "purge" command?, not working.....
modify ProcessPower.dcf file, only worse, make other ghost lines
You are not logged in.
Announcements
Need installation help?
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
