AutoCAD P&ID General
Valued Contributor
Heckmeck
Message 1 of 4 (464 Views)
Accepted Solution
Exclude Objects from Database
464 Views, 3 Replies
08-10-2012 03:46 AM
Hi Everyone,
I have a drawing with several symbols that serve as a caption.
For example in the upper right corner of the drawing, I show some special symbols with a description of them or some line types with their respective explanation.
Unfortunately, these symbols appear in the datamanger, since I added them via die tool palette and they are PID symbols.
I tried to add the caption to the *.dwt (drawing template), but you cannot add pid symbols there. (I produce a crash everythime I try...)
Is there an easy work around, to not show certain objects in the datamanager?
In a way, I would like to make some objects "stupid"
Best regards!
*Expert Elite*
dave.wolfe
Message 2 of 4 (451 Views)
Re: Exclude Objects from Database
08-10-2012 03:41 PM in reply to: Heckmeck
Explode them.
Dave Wolfe
Isaiah 57:15
ECAD, Inc.
Tips and Tricks on our blog: Process Design, from the Outside
A P3D Authorized Reseller
Valued Contributor
Heckmeck
Message 3 of 4 (430 Views)
08-12-2012 10:38 PM in reply to: Heckmeck
Thanks for the trick! Sometimes it can be so easy!
For those you read this: I had to type "._explode" in order to make the explode command work...else I got "unknown command"
Exploding blocks works great here, but I can't explode my pipes (mostly multilines/slines).
I tried with "pedit" but that doesn't work since mine are Slines.
I also tried with "flatten", but my colors will be lost if I use this command.
Do you have the trick for this one, too?
Thanks!
*Expert Elite*
Rave.Tam
Message 4 of 4 (425 Views)
08-12-2012 11:31 PM in reply to: Heckmeck
blocking those objects (sline as well) will also exclude them from the data manager. But u'll have problem editing the block later because editing P&ID objects in block editor is not supported.
If my post answers your question, please click the "Accept as Solution" button.
Check out my blog http://lazcad.com
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
