AutoCAD P&ID General
Active Member
Message 1 of 4 (445 Views)
End connection for fittings / piping specialty items in AutoCAD P&ID
445 Views, 3 Replies
02-04-2013 04:40 AM
It is possible to create property for identify end connections (welded, flanged) for fittings / piping specialty items as for hand valves in AutoCAD P&ID? I need to showflanged steap traps and y-type strainer on P&ID. Thanks in advance
Regards
Active Contributor
georgeendrulat
Message 2 of 4 (435 Views)
Re: End connection for fittings / piping specialty items in AutoCAD P&ID
02-04-2013 07:01 AM in reply to: cyklosarin
I tried everything I could think of, and nothing worked.  If it were me: I'd utilize different graphical styles for the item itself to differentiate between end types and manually insert flanges when needed.  That's the best I could come up with.  I looked through the database itself to see where the system property "EndConnections" resided, no luck.  Tried to create it manually, but the list seems to be a secret.  Tried setting the speciality item symbol to auto-nozzle, that was a disaster. If you or anyone here figures it out, please post it.
Active Member
Message 3 of 4 (422 Views)
02-04-2013 10:02 AM in reply to: cyklosarin
Thanks for the reply.
I Also tried to pick manually "EndConnectionts" property but without effect. I think it is somehow hardcoded by soft. For now the only way (beside what you wrote) is to pick such elements under "hand valves" & "instruments" category.
Active Contributor
georgeendrulat
Message 4 of 4 (416 Views)
02-04-2013 10:59 AM in reply to: cyklosarin
That's something I didn't consider.  Re-create the items under handvalves.  That's a solution, all be it a not so great one, but it should work.  I'm going to test it some more.
You are not logged in.
Announcements
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
