AutoCAD P&ID General
Active Member
cyklosarin
Message 1 of 4 (486 Views)
End connection for fittings / piping specialty items in AutoCAD P&ID
486 Views, 3 Replies
02-04-2013 04:40 AM
It is possible to create property for identify end connections (welded, flanged) for fittings / piping specialty items as for hand valves in AutoCAD P&ID? I need to showflanged steap traps and y-type strainer on P&ID. Thanks in advance
Regards
Valued Contributor
georgeendrulat
Message 2 of 4 (476 Views)
Re: End connection for fittings / piping specialty items in AutoCAD P&ID
02-04-2013 07:01 AM in reply to: cyklosarin
I tried everything I could think of, and nothing worked.  If it were me: I'd utilize different graphical styles for the item itself to differentiate between end types and manually insert flanges when needed.  That's the best I could come up with.  I looked through the database itself to see where the system property "EndConnections" resided, no luck.  Tried to create it manually, but the list seems to be a secret.  Tried setting the speciality item symbol to auto-nozzle, that was a disaster. If you or anyone here figures it out, please post it.
Active Member
cyklosarin
Message 3 of 4 (463 Views)
02-04-2013 10:02 AM in reply to: cyklosarin
Thanks for the reply.
I Also tried to pick manually "EndConnectionts" property but without effect. I think it is somehow hardcoded by soft. For now the only way (beside what you wrote) is to pick such elements under "hand valves" & "instruments" category.
Valued Contributor
georgeendrulat
Message 4 of 4 (457 Views)
02-04-2013 10:59 AM in reply to: cyklosarin
That's something I didn't consider.  Re-create the items under handvalves.  That's a solution, all be it a not so great one, but it should work.  I'm going to test it some more.
You are not logged in.
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
