AutoCAD P&ID General
Member
friday
Message 1 of 2 (350 Views)
End Connections at the end of the hand valve
350 Views, 1 Replies
02-07-2011 10:42 PM
Hello all,
Currently, when you right click the mouse on a handvalve, you can choose the kind of endconnections under the set endconnections. I was wondering if anyone know how to set the endconnection so that you have the flexibility of picking the  endconection at each end, instead of the same endconnections from both ends. For example, Flange conectiion at the inlet and Socket Welded at the outlet of the valve. If you know, please offer assistance. Thank you.
Luyen.
Employee
BuddyLegnon
Message 2 of 2 (268 Views)
Re: End Connections at the end of the hand valve
02-23-2011 07:34 AM in reply to: friday
what we need is the ability to select a flanged valve with a blind on then end or a plug on the end. That seems to be the most common issue we face with end connections on valves.
If my post answers your question, please click the "Accept as Solution" button (you must be logged in). This helps everyone find answers more quickly.
You are not logged in.
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
