AutoCAD P&ID General
Active Contributor
intratech
Message 1 of 4 (157 Views)
Customizing PipeLineGroup.Spec and PileLineGroup.Service
157 Views, 3 Replies
02-29-2008 06:39 PM
Hello, I like this discussion group.
I need custom data when I "Assign Tag - Pipeline".
Please advise how to customize SPEC data and SERVICE data of PipeLinegroup.
Thank you.
Active Contributor
intratech
Message 2 of 4 (157 Views)
Re: Customizing PipeLineGroup.Spec and PileLineGroup.Service
03-01-2008 05:58 PM in reply to: intratech
FYI, adding/removing data from the properties of "Pipe Line Groups" is ok,
What I want to know is where these data stored. is it customizable manually without PnPSDK ?
*Jorge Lopez
Message 3 of 4 (157 Views)
03-03-2008 11:45 AM in reply to: intratech
In the Data Manager, you will see a a Pipe Line Groups node. When you click
on this node you will see a list of all the groups and their properties.
What you are seeing is the records of a database table where the columns of
the table are the properties. The project database (.dcf) in the project
folder contains this table. You cannot customize it without the PnPSDK.
Thanks, Jorge
"intratech" wrote in message news:5863638@discussion.autodesk.com...
without PnPSDK ?
Active Contributor
intratech
Message 4 of 4 (157 Views)
03-03-2008 03:06 PM in reply to: intratech
Great! that's what I wanted to know. Thanks~
You are not logged in.
Announcements
Need installation help?
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
