AutoCAD P&ID General
Valued Contributor
Heckmeck
Message 1 of 1 (248 Views)
Crosshatch problem - Different results
248 Views, 0 Replies
04-09-2013 12:18 AM
Hi Everyone,
I multiple strange problems.
Our customer wants to have some symbols filled with color. I use crosshatches (solid) to fill the symbol with the desired color.
Problem No.1:
Adjusting the drawing order of the lines vs. crosshatch does not work.
The crosshatch always stays in the front. I have to redraw the lines after I place the crosshatch for the lines to be in front... ok so the outcome in the model space is as I want it to be. (see attached JPG "modelspace")
Problem No.2:
When I use "_exportpdf" or the corresponding button, the pdf outcome is exact the way I want it to be. (see attached JPG "exportpdf").
Since I have many drawings with multiple layouts to plot, I would like to use "_publish" or the batch plotting tool (I dont know the english name of the button).
Now please have a look at the screenshot "plot".
I tried everything.... redrawing the crosshatch, the lines, the attribute text.... nothing worked.
In the plotter settings, I tried every option ("mix lines" which works with the lines, but the attribute text still stays yellow). I can't imagine, why the yellow crosshatch passes its color to the attribute text.
Everything that is drawn in the block editor is on Layer 0.
Has anyone of you some hints on a possible solution?
Thanks!
You are not logged in.
Announcements
Need installation help?
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
