AutoCAD P&ID General
Active Member
iq206
Message 1 of 13 (1,367 Views)
Control Valves substitutions problem
1367 Views, 12 Replies
09-19-2012 04:22 AM
Hi
As in my subject I have some problems with control valves.
When I add new CV everything is OK, i can change actuators orz valve type, but during my project something happaned and I can't make any changes with CV (see attached file).
Plese Help.
Member
nfproductions
Message 2 of 13 (1,341 Views)
Re: Control Valves substitutions problem
09-20-2012 08:16 AM in reply to: iq206
I have this same problem, when inserting a CV the substitution pallet works as expected, until the drawing is closed. Upon reopening, the CV substitution will only yield options from inline instrument class, both for the body and the actuator. This is the case for all my CVs in both P3D 2012 and P3D 2013
hardell
Message 3 of 13 (1,302 Views)
09-26-2012 06:46 AM in reply to: nfproductions
It happens to me to. Does AutoDesk intend to fix the preoblem or are they just letting us stick with it?
//Johan
Active Member
iq206
Message 4 of 13 (1,299 Views)
09-26-2012 06:52 AM in reply to: iq206
Autodesk do NOTHING, but I'm used to it, and most problems solving itself.
This problem is still un solve and now I don't have much time to fix it.
craig.wood
Message 5 of 13 (1,288 Views)
09-26-2012 04:59 PM in reply to: iq206
I have a similar problem with control valves as well. The substitution menu often reverts back to the first class of inline instruments instead of valve bodies or actuators.
Active Member
iq206
Message 6 of 13 (1,279 Views)
09-26-2012 11:21 PM in reply to: iq206
Ok, but how to fix it?
Distinguished Contributor
Tee.Dee
Message 7 of 13 (1,063 Views)
11-15-2012 04:42 PM in reply to: iq206
This thread is almost a year old now, Does anybody have a solution to this problem? Im using 2013
Member
hiddink
Message 8 of 13 (882 Views)
12-12-2012 11:14 PM in reply to: Tee.Dee
I got the following answer from Autodesk
Try deleting the SubstitutionPalettes.xml from the root of the project.
After you have done this reopen the project and place a new control valve to check the substitution palette.
Note:
Existing contral valves that have the issue may need to be replaced in the drawing.
Martijn
Active Member
iq206
Message 9 of 13 (877 Views)
12-12-2012 11:50 PM in reply to: hiddink
I try this solution and nothing. But honestly, this solution is like my IT service team guy practice, computer restart for every problems.
Member
hiddink
Message 10 of 13 (875 Views)
12-12-2012 11:52 PM in reply to: iq206
For me it worked. Didn't see the problem anymore
You are not logged in.
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
