AutoCAD P&ID General
Distinguished Contributor
Tee.Dee
Message 1 of 6 (537 Views)
Control Valve properties HELP
537 Views, 5 Replies
11-15-2012 04:26 PM
I want to add property descriptions to Control Valves such as manufacturer, model etc. but when I click on a control valve, the valve and the actuator are combined so the Properties window sees it as selecting 2 different blocks and does not display any of the properties I need.
How do I go about adding information to these properties if I cant access them?
Keough
Message 2 of 6 (434 Views)
Re: Control Valve properties HELP
11-28-2012 06:31 AM in reply to: Tee.Dee
Are you using 2013? If so, it's difficult... Autodesk seems to not pay any heed to problems/suggestions by users and do whatever their programmers think is 'cool' or 'innovative'... Or at least that is my view of them thus far.
I've noticed in 2013 there is a litte box that appears at the top of the properties box that controls "PICKADD Sysvar", it will contain a "+" or "1". Changing this then picking the control valve and then holding shift while picking either the body or the actuator (I can't specify which one because its not consistent on which one will work). This will allow only the valve (body) to be selected which you should be able to edit from there.
But its painfully unconsistent.
Hope this helps at least a little.
Tee.Dee
Message 3 of 6 (419 Views)
11-28-2012 02:09 PM in reply to: Tee.Dee
Thanks Keough,
Yes im using 2013, not sure how I did it but now when I insert control valves the valve and actuator are not grouped anymore.  If you want to change the type of valve or actuator each symbol has its own pull down substitute menu arrow.
Speaking of the substitute menu, im still having problems as mentioned in this thread: http://forums.autodesk.com/t5/AutoCAD-P-ID/Control-Valves-substitutions-problem/td-p/3625424  pretty useless feature if it doesnt work and results in having to reinsert the valve if you want to change it.
Rave.Tam
Message 4 of 6 (386 Views)
12-04-2012 02:52 AM in reply to: Tee.Dee
To toggle selection of individual item in group, set pickstyle variable (0 or 1)
If my post answers your question, please click the "Accept as Solution" button.
Check out my blog http://lazcad.com
craig.wood
Message 5 of 6 (374 Views)
12-04-2012 07:53 PM in reply to: Tee.Dee
The only way I've been able to have this fixed automatically is to add the exact same properties (that are found under your control valve class) to your actuator class in order to have them display when clicking on any control valve. The only downfall to this is that you can't add certain acquisition properties to the actuator class like you can with the control valve class (ie: size, spec), since the actuator class can't acquire properties from the pipe line, but the control valve class can.
I hope this helps!
Craig
Tee.Dee
Message 6 of 6 (369 Views)
12-04-2012 07:58 PM in reply to: Tee.Dee
Thanks Rave.Tam, I should have realised this myself, I must have changed the value for another reason and thats how I got it working.
Thanks Craig, something else to think about to.
Anybody have an answer for the problem in the link I posted earlier in the thread?
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
