AutoCAD P&ID General
Active Member
mcost
Message 11 of 29 (1,034 Views)
Re: Control Valve Issues
02-24-2012 07:48 AM in reply to: jason.drew
Thanks for continuing to look into this! However, I am still getting the same, incorrect substitution palette.  :smileysad:
Member
Message 12 of 29 (1,030 Views)
02-24-2012 08:00 AM in reply to: mcost
Here no luck too. I compare the two XML files and find some differences but none of them looks like they are related to this problem.
P&ID was closed and reopened to countercheck. No luck.
Rave.Tam
Message 13 of 29 (1,028 Views)
02-24-2012 08:02 AM in reply to: mcost
Try set Pickstyle to 0, and select the individual valve. Then insert a new control valve and select the new valve. You'll see the difference in the Properties palette, which one of the style is set to Control Valve and the new one is set to Ball Valve.
I'm pretty sure this is a bug.
If my post answers your question, please click the "Accept as Solution" button.
Check out my blog http://lazcad.com
Distinguished Contributor
gschimmi
Message 14 of 29 (981 Views)
03-21-2012 11:52 PM in reply to: Rave.Tam
Hello
no more answers to the incorrect substitution palette?
Did I miss something?
GSC
Plant3D 2014 German
WIN7
Message 15 of 29 (919 Views)
09-03-2012 06:17 AM in reply to: gschimmi
The same substitution problem exists in P&ID 2013. Still no news?
Member
Message 16 of 29 (756 Views)
12-19-2012 05:11 PM in reply to: mcost
I'm seeing the same problem in P&ID 2013sp1.
craig.wood
Message 17 of 29 (734 Views)
12-21-2012 06:05 PM in reply to: mcost
We also have this issue in our project in P&ID 2013.
Active Member
composerv
Message 18 of 29 (482 Views)
10-18-2013 09:09 AM in reply to: mcost
Has this been fixed? I'm having the same problem!!!
Viktor K
Intel i7-3960X
48 GB Ram
Win-7 64bit
Quadro FX 5800
craig.wood
Message 19 of 29 (463 Views)
10-21-2013 07:04 AM in reply to: composerv
This has actually been fixed! You'll need to install "AutoCAD Plant 3D Extension 1" in order for the bug to be fixed. Once this update is applied, any NEWLY CREATED control valves will not have this problem. Substitution and copying/pasting control valves will now fully work and be stable. The big caveat here is that any pre-existing control valves that were placed before the update was applied will continue to have the problems mentioned above in this thread. This update also applies only to the Plant 3D Suite, and cannot be installed on standalone P&ID.
I believe you must have an AutoCAD subscription in order to access the update, but you'll see it listed here:
http://www.cadstudio.cz/download
(look under "Plant 3D, P&ID")
Craig
If my post is a solution to your issue, click "Accept as Solution" below.
Active Member
composerv
Message 20 of 29 (437 Views)
10-22-2013 07:55 AM in reply to: craig.wood
Really??? Autodesk fixed THEIR OWN problem for subscribers only!!!?? I would like this case to be elevated and fixed for all license holders. I know they have something extra in the download package that they want to give to subsc. only. Well, should they remove that "extension" and just release the fix only to all licensed users, so the software can do what it intended to do?
Thanks.
Viktor K
Intel i7-3960X
48 GB Ram
Win-7 64bit
Quadro FX 5800
You are not logged in.
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
