AutoCAD P&ID General
Active Member
stephanie.barrier
Message 1 of 6 (567 Views)
Check valve changes to gate valve
567 Views, 5 Replies
09-17-2013 11:38 AM
I'm trying to place a check valve in a line and it automatically changes to a gate valve.  I cannot substitue it in anyway to a check valve.  I finally just had to insert a dumb check valve block.  Anyone else have this problem?
Valued Contributor
peter.jansoone
Message 2 of 6 (553 Views)
Re: Check valve changes to gate valve
09-18-2013 07:01 AM in reply to: stephanie.barrier
is the symbol in the class (in Project Setup) still a check valve ? Maybe it was changed and the icon on the toolpalette still shows the old capture ?
Peter Jansoone
Plant Design software consultant at Greenock CAD service
Active Member
stephanie.barrier
Message 3 of 6 (550 Views)
09-18-2013 07:04 AM in reply to: stephanie.barrier
Yes, it is still defined in the project setup as a check valve, it has never been changed.
rr2013
Message 4 of 6 (541 Views)
09-18-2013 09:31 PM in reply to: stephanie.barrier
Try to check the Normally field under HandValves class. Make sure it has a default value. If you set that property with null value, any valve in the drawing will be substituted with gate valve.
craig.wood
Message 5 of 6 (429 Views)
10-03-2013 06:09 PM in reply to: stephanie.barrier
Yep, RR2013 is right. We had this same issue about a year ago and changing the symbol list value for hand valves to something other than null fixed the problem. I wish that symbol list wasn't automatically wasted on the "normally" property. It could be used for so many other things!
Craig
Employee
KenFauver
Message 6 of 6 (272 Views)
11-27-2013 12:44 PM in reply to: stephanie.barrier
If the post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Kenneth G. Fauver
Technical Sales Specialist – Plant
Oil and Gas Solutions
You are not logged in.
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
