AutoCAD P&ID General
joaquinr
Message 1 of 2 (474 Views)
Can you help. I do not resolve this error
474 Views, 1 Replies
01-15-2013 01:22 AM
good morning
to make the validation of the PID error I mark these lines,   always put the + (not connected). Delete the lines I restart and you're always the same, with the + and not with the dot indicating that this connected
Where is my mistake to draw?
best regards
joaquin
Valued Contributor
georgeendrulat
Message 2 of 2 (449 Views)
Re: Can you help. I do not resolve this error
01-16-2013 05:28 AM in reply to: joaquinr
Try moving/stretching the lines endpoint by osnap: "endpoint" to the offpage connectors node osnap:"Node".  This will connect the line to the off page connector.  When connecting one connector to another make sure you are connecting a "to" connector to a "from" connector.  You can tell which is which by the direction of flow on the line connected to the connector itself.
Hope this helps.
You are not logged in.
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
