AutoCAD P&ID General
cmcdonnell
Message 1 of 3 (216 Views)
Best Practice For Larger Spec PE Piping & Smaller Valves
216 Views, 2 Replies
06-02-2013 05:27 PM
New user to the p&id software. One thing I cant seem to get a handle on is valves when using PE Pipe
e.g. a 110mm PE pipe is equivelent to a 100mm PVC etc. It requires 100mm Valves.
As my valve takes the pipesize of the PE it displays 110 over all my valves and in the spreadsheets I export.
What is the best method for doing this as it also occurs with 375mm PVC, and ive no doubt will crop up multiple times in the future.
Colin
Product Support
VinodBalasubramanian
Message 2 of 3 (186 Views)
Re: Best Practice For Larger Spec PE Piping & Smaller Valves
06-03-2013 10:10 PM in reply to: cmcdonnell
Did you try to modify the selection list in the spec and catalog. Can you send me your drawing. I will try to add one and send you.
Vinod Balasubramanian
*Expert Elite*
Rave.Tam
Message 3 of 3 (174 Views)
06-04-2013 06:03 AM in reply to: cmcdonnell
How does the software knows 110mm PE pipe requires 100mm valves? I recommend you to create another property to fill in the OD (110mm). Fill in 100mm in the existing size property. The valve should automatically get the 100mm value. But then you'll need to update the line tag and annotation to point to the new OD property.
Or just can just override the valve size yourself.
If my post answers your question, please click the "Accept as Solution" button.
Check out my blog http://lazcad.com
You are not logged in.
Announcements
Need installation help?
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
