AutoCAD P&ID General
Active Contributor
Jan-TSpD
Message 1 of 2 (279 Views)
Autonumbering off page connectors
279 Views, 1 Replies
09-29-2013 06:27 AM
does anyone know how to change the project setup in order to create an OPC with an additional unique number corresponding with the connected OPC on another P&ID sheet. The number should automatically raise by 1.
Attached a screenshot of an OPC with the (example) number.
At the moment i only use 1 type OPC, so not an off page connector and an on page connector.
regards, Jan
craig.wood
Message 2 of 2 (238 Views)
Re: Autonumbering off page connectors
10-03-2013 05:53 PM in reply to: Jan-TSpD
Hi Jan,
I don't believe there is any easy way to do this outside of getting into the API.
I'm assuming that you'd want the unique number of one OPC to match the unique number of the OPC it is connected to. If that's the case, what I would do is to just create a numeric property in the OPC class called "ConnectorID", and then manually assign it to both affected page connectors. That's probably your best bet at this point.
I hope this helps!
Craig
If my post is a solution to your issue, please click "Accept As Solution" below.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
