AutoCAD P&ID General
Active Contributor
gri4775
Message 1 of 6 (437 Views)
AutoCAD P&ID 2014 and Vault 2014
437 Views, 5 Replies
11-07-2013 02:50 AM
Is this again the same in 2014?
Software Requirements
Autodesk Vault Server must be available to open or create vault projects. AutoCAD Plant 3D supports the following Vault Servers:
Vault Server Workgroup 2014
Vault Server Professional 2014
Or is Vault Server Basic 2014 also possible?
Product Support
Martin_Stewart
Message 2 of 6 (354 Views)
Re: AutoCAD P&ID 2014 and Vault 2014
11-19-2013 04:15 PM in reply to: gri4775
Correct, Vault Basic is not sufficient.
Installing for Autodesk Vault
http://docs.autodesk.com/INSTALL_LICENSE/2014/ENU/Autodesk%20Installation%20Help/files/GUID-2C569B99...
(If this answers your question, please mark it as an Accepted Solution.)
Martin Stewart
Support Specialist
Product Support
Valued Contributor
Message 3 of 6 (77 Views)
04-10-2014 06:23 AM in reply to: Martin_Stewart
This Autodesk site states that Vault Basic 2014 does support AutoCAD P&ID 2014.
http://help.autodesk.com/view/VAULT/Help/ENU/?guid=GUID-334CC890-1F12-429C-9D6A-B964327CA590
The AutoCAD P&ID 2014 Read Me file seems confusing.
http://docs.autodesk.com/PNID/2014/ENU/readme.html
Is there a document that explains how to setup Vault Basic 2014 for use with AutoCAD P&ID 2014?
Jerry
Autodesk Certified Instructor
Autodesk Inventor 2014 Certified Professional
Product Support
Martin_Stewart
Message 4 of 6 (63 Views)
04-11-2014 09:51 AM in reply to: gri4775
You can use P&ID with Vault Basic as you would with AutoCAD. However, for P&ID-specific functionality and projects, you’ll need the next level up on Vault. This information is also found at this help link:  Installing for Autodesk Vault
This help link includes information on using Plant 3D or P&ID with Vault (see video too): About Autodesk Vault
Martin Stewart
Support Specialist
Product Support
Product Support
Martin_Stewart
Message 5 of 6 (49 Views)
04-11-2014 03:59 PM in reply to: jberns
And this Autodesk University class link that may be of interest:  PD1335: Multi-site Workflows: The Good, the Bad, and the Ugly—An Advanced Look at Your Options  Some good info in the handout there on using Plant 3D with Vault.  FYI.
Martin Stewart
Support Specialist
Product Support
Valued Contributor
Message 6 of 6 (34 Views)
04-14-2014 06:20 AM in reply to: Martin_Stewart
Martin,
This Autodesk website does not indicate any limitation to the functionality of AutoCAD P&ID 2014 with Vault 2014.
The customer purchased based on this information. Shouldn't there be an asterisk next to the check mark to indicate a limitation to the product? Inventor projects are fully supported by Vault Basic. AutoCAD Electrical projects are supported by Vault Basic? Why not AutoCAD P&ID projects?
Jerry
You are not logged in.
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
