AutoCAD P&ID General
Distinguished Contributor
Tee.Dee
Message 1 of 3 (337 Views)
Annotation Style problem
337 Views, 2 Replies
10-29-2012 10:14 PM
I have created an annotation style for a control valve which works fine but I am trying to add the same annotation style to some other symbols and it gives me an error saying "Style xxx already exists in drawing!"
There are plenty of other symbols using the same annotation style as one another so what am I doing wrong here?
Thanks.
*Expert Elite*
dave.wolfe
Message 2 of 3 (325 Views)
Re: Annotation Style problem
10-30-2012 03:49 AM in reply to: Tee.Dee
You'll have to define it at a higher level in the class tree.  Annotations, like most properties, are inherited from parent classes.
Dave Wolfe
Isaiah 57:15
ECAD, Inc.
Tips and Tricks on our blog: Process Design, from the Outside
A P3D Authorized Reseller
Tee.Dee
Message 3 of 3 (317 Views)
10-30-2012 03:25 PM in reply to: Tee.Dee
Thanks Dave, that fixed it but now I have another problem.
The particular annotation style I have created is required to be used on every piece of equipment or instrument that has any I/O on it.  So at the moment if I annotate a control valve the Object Type and Loop Number are displayed but if I annotate say a motor, only the Type will display.
Is there a way to have the 'Loop Number' (for say a control valve) and the 'Number' (for say a motor) in the same attribute?
The way I have gotten around it at the moment is to have an attribute called #(TARGETOBJECT.LOOPNUMBER) and another attribute called #(TARGETOBJECT.NUMBER) on top of each other but this is not ideal as the attribute not being used still displayes the dot (.)
Thanks!
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
