AutoCAD P&ID General
Distinguished Contributor
Gabriel.N
Message 1 of 5 (717 Views)
Annotation RESET Problem
717 Views, 4 Replies
03-29-2011 03:02 PM
Actually I realize now  when I modify the  "projSymbolStyle.dwg" file happens the same thing  that when I change something in Project Proprites , all my annotations are reset.
Annex Before and After modify the "projSymbolStyle.dwg" file.
Gabriel.N
Message 2 of 5 (708 Views)
Re: Annotation RESET Problem
03-29-2011 09:29 PM in reply to: Gabriel.N
My God! This has been a really serious problem. I have sold the idea of AutoCAD P & ID since January for a client in Brazil. And this problem can really cripple the job. I've lost more than a month doing the customization of symbols, tags, styles etc. Because   every time I add a new item or modify this "blessed" file it resets my drawings.
Even if a document is already finished, if I open it just visualize, and if there are any changes made ​​in this projSymbolStyle.dwg, it mess all my annotations.
I'm completely lost!
Does anyone know how to contact  Autodesk directly ?
I was trying to sell the idea of AutoCAD Plant 3D, for the detailing phase of  project. But now I do not know.
Gabriel.N
Message 3 of 5 (661 Views)
03-31-2011 08:03 PM in reply to: Gabriel.N
I was able to solve some of the problems, but that persists.
Check the picture annex.
When the annotation resets seems to reset to the original length, before the stretch parameter do his work, stretching the oval graphic to embrace the TAG.
Other problem is the auto-insert Annotation, if it is able with prompt to TAG, my annotation goes to 0,0,0 coordinate. I guess it happens because the prompt for TAG insertion comes after the prompt for base point to annotation insertion; in my theory when that happens the TAG prompt over pass the Annotation prompt, putting it on 0,0,0.
Is there some alive here?
Employee
Message 4 of 5 (638 Views)
04-07-2011 07:37 AM in reply to: Gabriel.N
First let me apologize for the tardy response.
I am unable to reproduce the original issue in the latest software. Perhaps it is a bug we fixed.
If you click on the annotation and move it slightly, does it correct clipping of the line?
Can you try running SYNCHSTYLES from the command line to see if it helps?
Lastly, we do not script in annotation placements so the order of prompts should not affect placement.
In both cases, if you can provide steps to reproduce using a new project, I will make sure the issue is logged and addressed.
Thanks.
Jorge Lopez
Software Architect
Autodesk Plant Solutions
Autodesk, Inc.
Gabriel.N
Message 5 of 5 (634 Views)
04-07-2011 08:59 AM in reply to: Gabriel.N
Yes, when I triple click on annotation grip it fix the annotation. But if that I have to click all annotations to fix it.
The command SYNCHSTYLES didn't fix the problem.
About the steps to reproduce that I guess it must be some thing like that:
1- Draw a new Line;
2- Assign a TAG;
3- Annotate;
4- Go to Project Setup.
5- Make some change and click ok.
6- That is enough to reset the annotation.
Check the the annex "Annotation Problem 003.jpg" of my customized annotation to see if there is any problem there.
Check the the annex "Annotation Problem 004.jpg" to see the TAG format.
I thanks a lot for the attention that has been a headache.
I've reported another problems, please check them.
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
