AutoCAD P&ID General
New Member
Message 1 of 3 (249 Views)
Accepted Solution
Actuator default
249 Views, 2 Replies
12-04-2013 10:06 AM
How do I change actuator positions on a control valve from solenoid (default in P&ID PIP) to air actuated?  Also, how do I change the valve type from a ball valve to globe valve if I needed to?  Thank you for your help!
Product Support
quentin.contreras
Message 2 of 3 (230 Views)
Re: Actuator default
12-05-2013 03:19 PM in reply to: jimmy.stokes
If you select the Contol Valve you should be able to see two substitution grips that will bring up a substitution palette for changing the Valve Body and the Actuator. Here is the link to the help file that explains this in more detail.
To work with Control Valves in a P&ID Drawing
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Quentin Contreras
New Member
Message 3 of 3 (195 Views)
12-09-2013 08:42 AM in reply to: quentin.contreras
Thank you for your assistance!
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
