AutoCAD P&ID General
Active Member
derek.jarvis
Message 1 of 7 (338 Views)
API for saving drawings to AutoCAD
338 Views, 6 Replies
03-29-2012 10:28 AM
Is there something available in the API (or the command line) to automate the export of P&IDs from AutoCAD P&ID to the vanilla AutoCAD version?
Product Support
jason.drew
Message 2 of 7 (332 Views)
Re: API for saving drawings to AutoCAD
03-29-2012 01:53 PM in reply to: derek.jarvis
Currently there is not a "batch export" of any sort for P&ID.
That would require some API programming starting with "Resave all project drawings", then opening each drawing one by one, executing the EXPORTTOAUTOCAD command, and finally inserting the path where the exported DWGs are going to.
I will submit this as a feature request to the product team.
Thank you,
Jason Drew
Premium Support Specialist
Product Support
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly.
Active Member
derek.jarvis
Message 3 of 7 (328 Views)
03-29-2012 02:14 PM in reply to: jason.drew
Thank you for your response.
Have I interpreted correctly to assume that there is currently no API function to save a drawing to AutoCAD, and that this must be done through the "exportToAutocad" command?
Are there any API examples of opening / closing project drawings?
Product Support
jason.drew
Message 4 of 7 (294 Views)
04-04-2012 01:31 PM in reply to: derek.jarvis
Correct, to save as a "regular" AutoCAD drawing (where the symbols are converted to standard blocks and the annotations converted to attributed blocks) the proper method is to open the drawing, save it, then you can right-click and use "Export to AutoCAD"
You can still open an AutoCAD P&ID DWG in regular AutoCAD, but the objects will be proxy objects and you won't be able to display all of the properties in the properties window. Exporting would allow someone with regular ACAD to view all the properties as attributes of the symbol and annotation blocks.
Also, exporting would be recommended method for final delivery where you wouldn't want someone to have the ability to bring that DWG right back into AutoCAD P&ID. It's essentially a "dumb" P&ID after exporting.
On batch exporting, I would recommend posting the question on one of the customization forums here:
http://forums.autodesk.com/t5/AutoCAD-Customization/ct-p/1002
If it can't be accomplished through Visual LISP or AutoLISP, I would say you would need the Plant 3D SDK (software development kit) along with Visual Basic or Visual C# in order to write code to perform this from within the API.
Thank you,
Jason Drew
Product Support
Active Member
derek.jarvis
Message 5 of 7 (281 Views)
04-06-2012 01:44 PM in reply to: jason.drew
I have the Plant 3D SDK and would love to use a .Net solution to this problem. Unfortunately, I can't seem to find an API command to export the drawing to plain AutoCAD. Can you point me in the right direction?
Rave.Tam
Message 6 of 7 (274 Views)
04-08-2012 06:07 PM in reply to: derek.jarvis
check this post
http://forums.autodesk.com/t5/AutoCAD-P-ID/Silent-ExportToAutoCAD-command/m-p/3404431#M3395
Check out my blog http://lazcad.com
Active Member
derek.jarvis
Message 7 of 7 (254 Views)
04-13-2012 10:24 AM in reply to: Rave.Tam
Thanks for your reply.
I have managed to get the script solutions working, but I was hoping for an API solution to avoid having to open/close all the drawings in the editor.
Thanks to all who contributed to this post.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
