AutoCAD P&ID General
Active Contributor
john.brady
Message 1 of 4 (376 Views)
4 way valve with 2 line sizes
376 Views, 3 Replies
07-24-2008 04:33 AM
Say you have a four way valve, four piping connections like a cross. The pipe connected to ports at 0 and 180 are 3" while the pipe connected to ports 90 and 270 is 2". The data manager list the valve size as ? "multiple sources of information" is there a way to have two sizes shown without using a different line group?!?!
*Peter Quinn
Message 2 of 4 (376 Views)
Re: 4 way valve with 2 line sizes
07-29-2008 03:03 PM in reply to: john.brady
Sinner2009,
When I do it, I get the main line size showing up, not multiple. Your best
bet is to set up 2 addition size variable for the valve (like Size1, Size2)
and manually fill them in. In theory, you should be able to use the
propagation feature to automatically set them, but I was unable to tell it
to get other connections. It always gets the main one.
Peter Quinn
wrote in message news:5989368@discussion.autodesk.com...
Active Contributor
john.brady
Message 3 of 4 (376 Views)
07-30-2008 02:16 AM in reply to: john.brady
Yes that was the conclusion I came to also, our business however is 2, 3, 6, & 6 way valves(With two line sizes only). Normal inline valves are only utility. My users are not happy bunnies. Is this something that AutoDESK can look at. The valves are not line breakers, basically place the valve and bring the line too and from it but the real crunch is having the valve pick up two line sizes. We may have up to 300 of these valves on one P&ID so manually inputting a second size is a real pain.
Valued Contributor
phil.cooper
Message 4 of 4 (270 Views)
12-06-2012 06:41 AM in reply to: john.brady
any update regarding this as I have the same problem?
You are not logged in.
Announcements
Need installation help?
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
