AutoCAD P&ID General Discussion
Active Contributor
jessaskey
Message 1 of 10 (1,517 Views)
dissapearing crosshair cursor in 2012?
1517 Views, 9 Replies
02-03-2012 12:34 PM
Has anyone else had issues with the drawing crosshair cursor dissapearing in ACAD P&ID 2102? I can get mine to disspear semi-consistently which means I have to close and reopen the drawing, then it comes back. All I have to do in order to make it dissapear most of the time is hit ESC more than once, especially after panning or zooming (by hitting ESC or ENTER once after using the PAN or ZOOM, I get the crosshair back) I thought that I solved the problem by hitting ENTER instead to get away from the Pan or Zoom cursor but alas, that seems to be semi-consistent at getting the cursor to dissapear too. I realize the short answer is 'dont hit ESC or ENTER more than once' but Im just wondering what the deal might be... my machine or others too?
Is there some other way to return to crosshair cursor safely after using the Pan or Zoom toolbar buttons?
PS - I turned off hardware acceleration in settings, just to check, but that didn't seem to make a difference.
thank you
jess
dgrant775
Message 2 of 10 (1,513 Views)
Re: dissapearing crosshair cursor in 2012?
02-03-2012 01:50 PM in reply to: jessaskey
Yes, this seems to heappen with multiple viewports, either in PS or MS.  One one occasion I had to restart, but most of the time switching layouts or from model to paperspace works.  I've read it is a Windows 7 problem, but it also occurs on XP and Vista.  I've lost billiable time on the problem so it does need a fix.
Active Contributor
jessaskey
Message 3 of 10 (1,509 Views)
02-03-2012 02:40 PM in reply to: dgrant775
I had seen some other posts about this problem in the past and really had hoped it would have been fixed in SP1 that was released last week, but alas, it was not. It is a seemingly small problem but when it happens every 3 minutes, it becomes a very large problem.
Product Support
jason.drew
Message 4 of 10 (1,490 Views)
02-08-2012 09:35 PM in reply to: jessaskey
Jess,
This issue has been reported to development and they are looking into a solution. Can you reply back and let us know what type of video card you are using along with the driver version?
Also, I wanted to ask if you typically have the menu bar turned on or off while using P&ID. I have been able to reproduce this issue on my workstation by switching the menu bar on and off over and over and eventually I lose the crosshairs.
Your case is a bit different due to the fact that you can get the crosshairs to reappear. Typically it requires closing and opening the drawing to bring it back.
Thank you,
Jason Drew
Premium Support Specialist
Product Support
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly.
Active Contributor
jessaskey
Message 5 of 10 (1,487 Views)
02-08-2012 09:58 PM in reply to: jessaskey
Hi Jason..
Im running a Dell M6500 Precision Laptop
Windows 7-64
NVIDIA Quadro FX-3800M
Driver Version 8.17.12.8562 10/15/2011
Also, I have not been able to get my cursor back without closing and reopening the drawing, that was dgrant775 post.
thank you
New Member
PEPPIENZ
Message 6 of 10 (1,327 Views)
05-30-2012 03:23 PM in reply to: jessaskey
In my case the crosshair and cursor disappear only when I'm in a viewport. I can bring it back after changing to model space by hovering over the small [-] on the top left hand corner. Never needed to re-open a drawing.
Active Contributor
jessaskey
Message 7 of 10 (1,310 Views)
06-01-2012 09:15 PM in reply to: PEPPIENZ
This is still an issue with me in 2012, but I did notice one way that I can make the issue dissapear completely, all I have to do is to use an external mouse rather than the touchpad on my Dell M6500. If I do that, the crosshair never seems to dissapear. Strange.
Im going to 2013 next week so hopefully the issue just dissapears completely. :-)
Active Contributor
tgwestbrook
Message 8 of 10 (1,248 Views)
06-26-2012 07:47 AM in reply to: jessaskey
WIth 2013 we are still seeing (or rather not seeing) the dissapearing crosshairs on a fairly regualr basis.   It seems to be an issue in the base Autocad platform rather than just Plant3D or P&ID,  I have seen it in vanillar Autocad and other verticals.
 Sometimes mousing over 'Viewport Controls' in the upper left works, sometimes it doesnt.
It happed last week in training as well, on the VAR's machine.    Our Workstations are Dell T3500 with Nvidia Quattro 2000 & 4000, latest ACAD approved drivers.  The VAR's workstations were Dell T1500.
New Member
PEPPIENZ
Message 9 of 10 (1,123 Views)
08-28-2012 05:15 PM in reply to: jessaskey
Yep, I've got the menubar always turned on.
I've just changing to version 2013 doesn't help as it happens there as well.
Should we now rename the 'cursor' to 'Curser'?
Member
kjbike7
Message 10 of 10 (808 Views)
03-04-2013 08:32 AM in reply to: PEPPIENZ
my crosshairs disapprear in paperspace constantly.   especially if i work on model space then switch to paperspace.   the only way i have found to fix is to shut down autocad.  i am using rel 2013 full version cad.
very time consuming and aggrevating.
Any solution?
You are not logged in.
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
