AutoCAD P&ID General Discussion
Active Contributor
Jan-TSpD
Message 1 of 14 (567 Views)
Accepted Solution
Valve is replaced when assigning tag
567 Views, 13 Replies
11-26-2013 06:04 AM
Hello, i have a P&ID which is copied from another P&ID. After this i assign a tag to a valve, when i click the assign button the tag is re-assigned, but also the valve is replaced by a valve from another (standard PIP) class. This valve is not one of my standard classes, so i can not substitute this valve by another.
Attached an mp4 of the situation.
regards, Jan
Product Support
quentin.contreras
Message 2 of 14 (560 Views)
Re: Valve is replaced when assigning tag
11-26-2013 04:49 PM in reply to: Jan-TSpD
If you copied a P&ID dwg file from another project and are placing it in a new P&ID Project, then that might be why you are seeing the issue. The other project has it's Project Setup settings different that the Project you have copied this drawing too. If you are wanting the projects to match you should have created a new project based off the existing project where you brought the drawing from.
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Quentin Contreras
Product Support
gersteb
Message 3 of 14 (533 Views)
11-29-2013 05:37 AM in reply to: Jan-TSpD
Hello Jan,
the reason therefore can be that symbol scale of imported P&ID was different than the one of your project. Look for the symol scale via 'Edit Symbol' of the class (see attached snapshot).
For a working substitution four things have to be set:
  • The classes are in the same class folder
  •  The classes have all a defined symbol
  •  The property 'Substitute' have been set to 'true'
  •  The property 'SupportedStandard' supports the same norm. Therefore select the property and click 'Edit'. Check the settings there.
Regards
Bernd
Bernd Gerstenberger
Active Contributor
Jan-TSpD
Message 4 of 14 (499 Views)
12-04-2013 12:11 AM in reply to: gersteb
Hello Bernd,
it happens also when copying a drawing from the same project with same projectsetup. It happens randomly.
Scale of all valves in the project is set to "1".
Jan
Product Support
gersteb
Message 5 of 14 (496 Views)
12-04-2013 12:54 AM in reply to: Jan-TSpD
Hi Jan,
maybe your symbol definition has changed during the lifecycle of your project. Please, set the scale to 10 or another value for this valve symbol adn try again.
Regards
Bernd
Bernd Gerstenberger
Active Contributor
Jan-TSpD
Message 6 of 14 (492 Views)
12-04-2013 02:22 AM in reply to: gersteb
Hello Bernd,
no, the symbol definition did not change during the project.
regards, Jan
Active Contributor
Jan-TSpD
Message 7 of 14 (491 Views)
12-04-2013 02:28 AM in reply to: gersteb
Hello Bernd,
the valve from my class is replaced by a valve from the PIP class (PIP Gate Valve). This valve is not in my project at all.
regards, Jan
Product Support
gersteb
Message 8 of 14 (487 Views)
12-04-2013 02:34 AM in reply to: Jan-TSpD
Hi Jan,
are you able to send me the whole project? You will get a separate email with the access data for a FTP-site from me. Also name the class where I have to look for exactly.
Regards
Bernd
Bernd Gerstenberger
Active Contributor
Jan-TSpD
Message 9 of 14 (485 Views)
12-04-2013 02:37 AM in reply to: gersteb
Hello Bernd,
that is okay.
regards, Jan
Active Contributor
Jan-TSpD
Message 10 of 14 (474 Views)
12-04-2013 06:53 AM in reply to: gersteb
Hello Bernd,
the replacement only happens with P&ID's that are copied into the project, both projects have the same project setup.
When assigning a tag to a valve or substituting a valve, the valve is replaced with a PIP globe valve (which is not in the project).
Attached a mp4 file
regards, Jan
You are not logged in.
Announcements
Need installation help?
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
