AutoCAD P&ID General Discussion
Active Member
rrui00
Message 1 of 3 (286 Views)
Size of Globe Valves
286 Views, 2 Replies
06-01-2012 01:04 PM
For some reason the size of automatic globe valves is smaller than the rest of automatic valves (ball etc..) and that manual globe valves.  Anyway to change the size of predefined valves?  See picture attached.
Employee
KenFauver
Message 2 of 3 (281 Views)
Re: Size of Globe Valves
06-01-2012 02:49 PM in reply to: rrui00
This can be changed by editing the block properties from within the project setup.
If the post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Kenneth G. Fauver
Technical Sales Specialist – Plant
Oil and Gas Solutions
Active Member
rrui00
Message 3 of 3 (250 Views)
06-04-2012 07:13 AM in reply to: KenFauver
Thanks, that helped.
I have about 40 P&IDs, and when I change the block, it automatically updates them all, but the lines are not connected to the new valve, see snapshot attached.
I have to go one by one and change the valve type, change it again to the one I want and at that point YES, the lines are properly connected.
Any way to avoid doing this to every single valve?
You are not logged in.
Announcements
Need installation help?
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
