AutoCAD P&ID General Discussion
Product Support
gersteb
Message 11 of 26 (504 Views)
Re: Modify Report - can't add/remove colums
11-12-2013 05:49 AM in reply to: andreas.hammer
Do that to get back the line summary list:
  • Open project configuration, switch to the node 'General Settings - Reports'
  • Create a new report with the name 'LineSummaryList'. It doesn't matter which you report template you use for the creation of this report.
  • Open Windows Explorer and switch to a different project, subfolder 'ReportTemplates'
  • Copy the 'LineSummaryList.xml'
  • Paste and replace the 'LineSummaryList.xml' in your current project
Now the report is restored. Does this work for you?
Regards
Bernd
Bernd Gerstenberger
Active Contributor
andreas.hammer
Message 12 of 26 (501 Views)
11-12-2013 06:17 AM in reply to: gersteb
The list is restored, but the same thing happened. This is really strange!
I tried purging the local data cache again, which didn't help. I also tried creating a report with a different name, but no luck there.
I copied the LineSummaryList from the program folder, so the problem shouldn't be there.
When I hit the save button the list changes (not the columns), see attachment, before and after save. The XML file changes as well.
Product Support
gersteb
Message 13 of 26 (481 Views)
11-13-2013 06:15 AM in reply to: andreas.hammer
Can you try it with a new project?
Bernd Gerstenberger
Active Contributor
andreas.hammer
Message 14 of 26 (474 Views)
11-14-2013 12:42 AM in reply to: gersteb
I created a new project without copying the project settings from the other project and the problem was still there. I could not add or remove columns in the Line Summary List. All the other lists works fine.
Product Support
gersteb
Message 15 of 26 (463 Views)
11-14-2013 07:42 AM in reply to: gersteb
I have attached a copy of my template. Please, replace your template with this one. Does this work?
Bernd Gerstenberger
Product Support
gersteb
Message 16 of 26 (461 Views)
11-14-2013 07:44 AM in reply to: gersteb
There is an issue currently when attaching files to the posts. I will send you the file directly via email.
Bernd Gerstenberger
Active Contributor
andreas.hammer
Message 17 of 26 (450 Views)
11-15-2013 12:19 AM in reply to: gersteb
No, it didn't help that either :/ I tried on two different projects.
Active Contributor
andreas.hammer
Message 18 of 26 (443 Views)
11-15-2013 02:08 AM in reply to: andreas.hammer
I would also like to mention that I checked the report lists on another computer, and the problem was still there.
Product Support
gersteb
Message 19 of 26 (438 Views)
11-15-2013 07:52 AM in reply to: andreas.hammer
I can recreate the issue. Sorry, my fault. I have tested it with Plant 3D 2014 and there it works fine. I have logged now the issue to our development department. As you have already said, I can confirm that export to Excel works fine. Thank you for your patience.
Bernd Gerstenberger
craig.wood
Message 20 of 26 (433 Views)
11-15-2013 09:17 AM in reply to: andreas.hammer
Andreas,
Just some food for thought...
The Report Creator is so much more powerful and will be worth learning in the long run. I actually learned how to use it pretty quickly with the help of an instructional video on youtube, along with the help of that 250 page whitepaper as a reference. I suggest starting there...you'll be glad you did :smileyhappy:
Craig
Announcements
Need installation help?
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
