AutoCAD P&ID General Discussion
New Member
cadreddy
Message 1 of 14 (507 Views)
Layout scale....
507 Views, 13 Replies
10-05-2012 11:46 PM
How to change the Layout scale................plz telme anybady....................
Valued Contributor
azmand01
Message 2 of 14 (252 Views)
Re: Layout scale....
06-18-2013 07:35 AM in reply to: cadreddy
Amazing.
254 Views and no reply.
I knowit is an old post.. but have you sorted your problem out?
I am trying to get rid of a duped scale definition.. I have a 1:1 scale and a tbd 1:1 (to be deleted).
..and I noticed that this tbd scale is stuck at the layout... So no selection is made but the it shows on Properties.
See picutre.
Anyone witha LIsp or else to help us out.
*Expert Elite*
Rave.Tam
Message 3 of 14 (234 Views)
06-19-2013 07:55 AM in reply to: azmand01
Maybe because his question is not clear enough?
Change your model space annotation scale to 1:1 and use scalelistedit to delete the custom scale. Anyway, you will probably ask in the AutoCAD forum for quicker response.
If my post answers your question, please click the "Accept as Solution" button.
Check out my blog http://lazcad.com
Valued Contributor
azmand01
Message 4 of 14 (230 Views)
06-19-2013 08:06 AM in reply to: Rave.Tam
Thanks for reply ...but that won't work.
Have you look at the picture?
Scale on Model space is 1:1
Already purged all objects.. Deleted all objects.. empty DWG dry.
Alos tried  using this .NET plugin from Kean Walmsley
http://through-the-interface.typepad.com/through_the_interface/2011/10/delete-all-but-current-annota...
.and then I realized that a Layout tab can actually have a scale set by having all un-selected and looking at Properties I could find the locked up scale.
And the interesting thing is that I have other layouts in this template that scales are set to correct 1:1 scale and not to bugged duped 1:1 scale (that I renamed to tbd) see picture on previous post.
Thanks for help.
*Expert Elite*
Rave.Tam
Message 5 of 14 (226 Views)
06-19-2013 09:05 AM in reply to: azmand01
I can only see a properties palette in you screenshot, which doesn't say anything about the scale of your model space.
Did it shows up on the scale list at all? Have you try reset the scale list?
Valued Contributor
azmand01
Message 6 of 14 (223 Views)
06-19-2013 09:09 AM in reply to: Rave.Tam
Highlighted in Blue
Misc
Annotation Scale - tbd
*Expert Elite*
Rave.Tam
Message 7 of 14 (220 Views)
06-19-2013 09:17 AM in reply to: azmand01
Yes, that's your model space scale, tbd. What i mean is that i couldn't find where does it say 1:1 like you mentioned.
Mind to attach the drawing?
Valued Contributor
azmand01
Message 8 of 14 (218 Views)
06-19-2013 09:20 AM in reply to: Rave.Tam
Sorry,,
Explaining
tbd is a renamed bad scale wit ha definition of 1:1
It can not be named as 1:1 because another 1:1 scale already exists in DWT.
Like this
Scale Name   Definition
1:1                     1:1
tbd                     1:1
*Expert Elite*
Rave.Tam
Message 9 of 14 (216 Views)
06-19-2013 09:29 AM in reply to: azmand01
I see. What the value of "CANNOSCALE"? Doesn't Resetting the scale list remove it?
Valued Contributor
azmand01
Message 10 of 14 (212 Views)
06-19-2013 09:35 AM in reply to: Rave.Tam
Tried 0 and 1
Announcements
Need installation help?
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
