AutoCAD P&ID General Discussion
New Member
MK531977
Message 11 of 13 (481 Views)
Re: Control Valves substitutions problem
01-07-2013 03:12 AM in reply to: hiddink
i have got the same problems with the control valves. Of course deleting of this substitution file works, but changing every cv that has the same issue is very unproductive and waste of time.
Is there any other solution to this problem?
Distinguished Contributor
Tee.Dee
Message 12 of 13 (420 Views)
02-11-2013 06:22 PM in reply to: MK531977
This fix didnt work for me either.  This program is supposed to save time instead it just seems to create endless problems that have no fix.
Discussion_Admin
hardell
Message 13 of 13 (343 Views)
02-27-2013 05:46 AM in reply to: iq206
I´m so tired of this problem. I had it a couple of months ago, and fixed it by manually remove and add controlvalves.
Now it has appeared again and I can't just make it for hundreds of valves. It is not just possible in projects.
Autodesk: You must make a product that keep data consistent!!! It is the single most important thing with a P&ID processinformation software!
//Johan
You are not logged in.
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
