AutoCAD P&ID General Discussion
Member
Compressor-01
Message 1 of 3 (440 Views)
ACAD P&ID 30 day trial and trying to make something happen ASAP! :)
440 Views, 2 Replies
01-31-2011 08:57 AM
Hello all. I have recently downloaded the 30 day trial in an attempt to prove to my company that we need this valuable tool.
In doing so, I am attempting to creat some of our needed P&ID's
I have opened a new file and began by trying to insret a "recipricating compressor" component in the model space directly from the tool pallet. I have chosen the P&ID DIN workspace tool pallet.
I see all the tools I need, but can not get them to be applied to begin a drawing. I have tried placing a pneumatic line first and then applying the compnent as well to no avail.
I am sure it is just a matter of the correct process and the correct format.
Can someone point me in the right direction to get started?
Thanks!!!
Distinguished Contributor
tom_pe
Message 2 of 3 (396 Views)
Re: ACAD P&ID 30 day trial and trying to make something happen ASAP! :)
02-03-2011 08:35 AM in reply to: Compressor-01
If the software installed correctly, this should be real easy. Pick a piece of equipment on the tool palette using the mouse. Move to the drawing and select an insertion point. Select a line on the tool palette. Then pick a starting point on the drawing and pick the next point as a connection to you piece of equipment.
If you can't do this, there may be something wrong with your installation.
Tom
Employee
BuddyLegnon
Message 3 of 3 (327 Views)
02-14-2011 08:09 AM in reply to: tom_pe
heres a tip - watch the online videos first - then dont drop and drag..just click once on the palette then click to place on the dwg area.
It is the best tool, and do yourself and your company a favor - get an Autodesk onsite demo and make sure the suits are in attendance.
:smileywink:
If my post answers your question, please click the "Accept as Solution" button (you must be logged in). This helps everyone find answers more quickly.
You are not logged in.
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
