• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Mechanical
    ballon text size
    192 Views, 5 Replies
    12-03-2012 12:12 AM
    I am new to the world of bom's, partlists & balloons
    I am having trouble changing the text size of the text in the balloons.
    Can anybody help me with this?
    Please use plain text.
    Re: ballon text size
    12-03-2012 10:48 PM in reply to: leandrav
    Options > AM: Standards > Balloon > Default style > Standard (click three dots) > Text > Height
    (ACADM 2008)
    12-03-2012 10:55 PM in reply to: leandrav
    Thanks for the reply.
    I have tried that. I can't seem to get it higher than a size of 20.
    I can't put my own size in I can only choose from what is in the drop down list.
    12-05-2012 10:39 PM in reply to: leandrav
    I have attached a picture in hopes that this will help someone give me advise.
    This s a pdf to a scale of 1:30 & on this you can't really see the numbers in the balloon that well.
    I am looking for a way that i can increase the size of the text so that it can be read at a scale of 1:100 at least.
    I have tried changing the size as perviously mentioned but I can't go bigger then 20 & I can't pick my own size. I can only pick from what is on the list
    Leandra
    Employee
    12-06-2012 12:54 AM in reply to: leandrav
    Hi Leandra,
    Instead of changing text height, have you thought about changing the scale like set AMSYMSCALE to 100? If you place a balloon, you should be able to see the text inside the balloon.
    Hope it helps.
    Thanks.
    Michael Su
    SQA Engineer
    Please mark any response as "Accept as Solution" if it answers your question.
    12-06-2012 01:08 AM in reply to: michaelsu
    THANK YOU!!!
    That works perfectly!!
    You are a genius .:smileyvery-happy:
