• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Mechanical
    Member
    VIEWBASE command help
    204 Views, 6 Replies
    07-24-2012 03:03 PM
    When I use the viewbase command in AutoCAD Mechanical 2012 I get the dialog as shown.
    When I select my Inventor part, and click open, AutoCAD throws an error saying 'Invalid Autodesk Inventor file C:\...' See below:
    I am using Inventor 2012 and Mechanical 2012. I want to be able to get 2D views of my .ipt files in Mechanical.
    Any help with issue would be much appreciated.
    Please use plain text.
    Employee
    Re: VIEWBASE command help
    07-24-2012 06:25 PM in reply to: idwt13
    Can you try to save the ipt file in Inventor 2012 again and then try it in AutoCAD Mechanical 2012?
    if it doesn't help, could you please share the file to me for further investigation?
    Thanks.
    Michael Su
    SQA Engineer
    Please mark any response as "Accept as Solution" if it answers your question.
    Member
    07-24-2012 07:27 PM in reply to: idwt13
    It actually does this same thing with every ipt file I try. I have also tried iam files and they don't throw the error, but they don't place the view. Strange. I also just tried creating an ipt of a plain old box, saved it in Inventor 2012, and it still gave me an error. Is there any settings in Inventor I should have set-up?
    Employee
    07-26-2012 11:15 PM in reply to: idwt13
    Sorry, I could not reproduce this issue you mentioned. Could you please provide more information?
    Can you try please try whether you can use VIEWBASE command for 3D solids in Model Space?
    The step is, draw a box in model space, and then go to layout and use VIEWBASE to create drawing views.
    Can you also try whether you can use inventor link feature in AutoCAD Mechanical?
    The step is, Go to A button in the left top corner of AutoCAD Mechanical-> New -> Inventor link, then use AMDWGVIEW to create views from it.
    Also, could you please let me know from what installer you have installed Inventor 2012 and AutoCAD Mechanical 2012? What build version of Inventor are you using? Have you applied the service pack for them?
    Thanks.
    Michael Su
    SQA Engineer
    Member
    07-27-2012 07:56 AM in reply to: michaelsu
    Answers in red.
    Yes, this does work.
    Yes, this does work also.
    I am using:
    Mechanical 2012 (F.107.0.0) Service Pack 1 - 64-bit
    Inventor 2012 (Build 190) Service Pack 1 - 64-bit
    Member
    07-27-2012 08:22 AM in reply to: idwt13
    I don't know what happened to my software, but it just cleared itself up. I wonder why? Very wierd.
    Thanks all for your help!
    Employee
    07-29-2012 05:59 PM in reply to: idwt13
    You are welcome!
    Very glad to hear the problem solved.
    Let me know if you have more concerns.
    Thanks.
    Michael Su
    SQA Engineer
